First year with a pool and I am getting some mixed information from local pool builders on how concerned I should be with ice on top of pool. I have a partially inground gunite pool on a hillside, that faces north. North side of pool looks like an infinity edge, but the pool does not spillover. Pool has no deck on the northside, if that makes sense. Pool is open all year round and I run an automated freeze protection controlled with Omni Hub. My question is how concerned should I be with the top of my pool freezing during extreme cold spells? We had some temps dip into the single digits for a few days and I had a good 4" of ice accumulate on the top of my pool. Pumps stayed running and the water did not freeze at the skimmers, spa spillover or the floor bubblers, but the rest of the top of the pool had a good 4" of ice and the spa had about 1". I have read that the ice on the top of the pool is not an issue, but I have also been told that I should break the ice if it starts to build up. My pool being on a hillside and partially above ground on 1-1/2 sides, I did not know if the ice could be a structural concern pressing on the gunite shell without having fill on the outside? Is the tile at risk with the freezing water since the water level is above the tiles?
I have considered running my heater to keep water temps warm enough to not worry a bout it, but my Hayward heater manual says to not use the heater for freeze protection. Just trying to get some feedback from folks with experience of their pool freezing over while running pumps with freeze protection.
