Three waterline tiles came loose and I am looking for the best way to re-attach them without draining the pool (I have no way too unless I rent a pump or wait for evap). One of them is broken. So far based on research on here I have found two products which ought to work but I have questions about both.
I bought this product because it is cheap and available and I can have more leeway if I have to waste any trying to mix it. But now I'm finding out that I can't use it as grout? That I would need to buy grout separately? Also, I am unsure with using thinset that I would need to remove the existing thinset from the pool wall? I was hoping not to have to do that since the pool is full and it also seems like a giant pain in the butt to try and chip it out especially with water in the pool. Also, there is grout still on the tile edges. Do I need to grind that off as well?
This product is expensive and I'm afraid if I don't mix it perfectly I will waste alot of money and I have to order it. But it seems like you can also use it as grout? And the instructions say nothing about having to chip off the old thinset or grout. Is that true for this?
I also saw a video where someone used this, but the demonstration was above the water line. Does anyone know if this can set and adhere below the waterline?
Any advice on which product to use or whether my assumptions are right or wrong? How critical is this repair? It's ugly as heck, but do I need to repair this as quickly as I think I do? I've been researching this all night thinking I have a huge problem on my hands, but my pool issues always affect me that way. And I'm not the most handy or DIY person. so Is this above my pay grade for someone who has never done a tile repair before?
Thanks.
Custom Building Products 1.5 lb. White Tile Repair Mortar-TRMW1 - The Home Depot
Find the Tile Repair Mortar 1.5 lb. Powder Mortar TRMW1, resists mold and mildew fast-setting formula helps you perform same-day grouting at The Home Depot
www.homedepot.com
Amazon.com : E-Z Patch 4 White Pool Tile Grout for DIY & Pro Repairs - Color Adjustable Grout Refresh (3 lb) : Garden & Outdoor
www.amazon.com
Boss Silicone RTV 100% 315 Clear Sealant, 3 oz. Tube: Amazon.com: Industrial & Scientific
www.amazon.com
Thanks.
