Hello everyone,
I’m going to share as much info as possible so if this is wordy I apologize.
Pool: Salt water, vinyl liner, opened last week so was running.
Today, some extremely strong winds blew our outdoor patio set into the pool. A tiki torch jar filled with fluid was on the table and was blown into the pool as well.
I saw air bubbles floating up when I got in from work, however I’m not sure if the liner is damaged. I was able to easily remove the base of the table but need a hook for the rest.
Also, I did turn off the pump but it was probably running a while before I got home.
If the liner isn’t damaged what can I do to make it safe for my family again? I’m concerned about the tiki torch fluid. It was likely about 16oz.
Thanks for all of your help in advance!!
