Most residential standalone hot tubs are all electric-120v or 220v no need for a gas line .
In PA I suspect you’ll be happiest with a 220v tub. One that can heat & run the jets simultaneously.
This will require a dedicated circuit & wiring.
You should shop around (actually sit in some tubs) and decide what features are important to you for how you will use the tub as well as considering your budget.
Example: Just you & the wife or kids and grandkids- heavy use or occasional use etc.
waterfall? radio? Lots of jets in specific places? Loungers? Things like that.
features like ozone can be helpful for frequently used tubs to help oxidize waste but can consume (oxidize) alot of standby fc so not as helpful and a bit counterproductive for those who only use them once a week for example.
The more bells & whistles the higher the cost & the more to eventually break in my opinion but everyone has different tastes.
I personally don’t like molded seats or especially loungers (they drown me because I am short) but every one is different.
*Hot tubs have a much heavier bather load than pools due to the small volume so the sanitizer demand is more intense.
Having 2 -4 people in a 400 gal hot tub is like having a frat party in an average size pool so you must maintain the sanitizer accordingly. This trips many people up at first. Don’t be afraid to properly sanitize the tub.
& do purge with ahhsome as soon as you get it.
This is a chlorine based forum so that’s the sanitizer we recommend although there are guides here for both chlorine & bromine
(They are also pinned
to the top of this subforum)
If you have a question about any information within this Sticky, please start a new thread for yourself where you will receive very quick responses to your specific questions. Thank you! Introduction There are two main things to consider when maintaining your hot tub water, Water Balance and...
www.troublefreepool.com
Originally Posted by waterbear There is a lot of misinformation on the proper way to use Bromine so I hope this primer is helpful. First, you need to establish a bromide reserve in the water. Bromine tablets can do it by themselves but it can take literally weeks until enough dissolves. Some...
Many chlorine users here choose to have a saltwater chlorine generator take care of the standby chlorine needs and just manually dose as needed depending upon bather load.
Some manufacturers offer their own systems for this and there are also aftermarket drape over systems available.
A titanium heater is recommended for use with salt.
Most spa swg systems use a lower ppm level than pool systems (around 2000ppm).
Budget-
There are $2k starter tubs & $10k+ tubs-
If you’re looking for a tub that will last a long while (10+ years) you’ll want to deal with a local reputable dealer and a well known brand that can offer service incase of warranty claims etc. This will come with a price tag but also peace of mind.
The $2-$5k online tubs can be much harder to obtain service and parts for.
I personally have a “budget/starter” tub & am capable of doing my own service/repairs but not everyone is. It ticked the boxes for price, size, & layout for us not knowing if we’d actually use it. Surprise! We are apparently hot tub people!
Also, Most budget tubs are “full foam” like spray foam,
which sounds great & insulating (it is) but they are a booger to deal with if there’s a leak in the plumbing or otherwise.
That’s all I can think of for now,
I am sure Rdspaguy will have some more really helpful stuff to look out for as well when he comes along as he has serviced many brands & types.
Hopefully these points will help you narrow down your choices some.
Feel free to post some of your prospective choices for more pros/cons as models can vary greatly.
