Hello,
I'm thinking about changing my pump. My existing pump is some generic Black and Decker 2 speed 1.5hp that looks like it was built in a Chinese build house that makes store brand stuff. Available speeds are 1720 and 3450 rpm. It has a qmax rating of 92gpm. I imagine that's the max flow at 3450 rpm. Per the label, it pulls 12amps on high speed and 4.8 on low speed. Last year I ran it on high for 7 hours a day. This year I was planning on running it on low for longer period of time.
This year, Ill need it to flow enough for a mastertemp 300 to operate. The flow range on it is 30-120gpm. I have no clue what the existing pump flows on low. Maybe someone here knows.
I plan on using a Pentair IC40 next year. The flow range on that is ~25 to 80 before a bypass is recommended and I didnt build a bypass for where it's going. I could add one though.
Im GUESSING that my pump on low will flow enough for the heater and salt cell. On high, it may be good for the heater, but possibly too much for the salt cell. I won't know until I try it.
Now, Im obsessing over maybe buying a new pump.
Im considering the Pentair Superflo 1.5 or Intelliflo pumps. The 3hp is way overkill for my basic pool, but I see people saying to get the bigger pump and run it low. I also like that it has 2 inch unions since I have 2" plumbing. I feel like a 1.5 is already bigger than I need but I want opinions on that.
I have an intelliconnect which Penair says is compatible with Superflo, Whisperflo and Intelliflo pumps. I only see Intelliflo in the app as an option, but they stated in an email that those 3 pumps can be controlled via rs485. I would need their connector and only us 2 wires on it.
I should also note that I can easily change from 120v to 240v if I need to.
Also, with the new plumbing, I get a whirlpool in my skimmer with the existing pump on high. Its not enough to suck in air, but its clearly visible.
Im leaning towards a superflow 1.5 if I can control the running RPM in the Intelliconnect app.
What are everyone's thoughts?
