Firstly--thank you TFP. This forum saved the day for us and we had an easy pool maintenance year.
Now it's quite cold here in TN and we'll be closing it soon, and finally there is some confusion.
I've used the DPD/R-0870/R-0871 test daily all year because our goal TC was 7 (after a high CYA and partial refill in the spring). Over the season CYA came down further ending at a CC goal of 5. Anyway, it worked perfectly....
Now that it's cold it's only needed a small amount of bleach everyday. The last week the DPD/R-0870 test only shows clear, but the K-1000 test turns yellow. What does that mean? Essentially getting a 0 chlorine read with one method and a correct one of about 5 with the other.
Just hoping to make if through these last weeks before covering it for winter.
Thanks for the help! This is a great community.
15200 gallon - above ground vinyl liner
