I love the TFP method and community but this is something that has always bothered me. It's not clear whether or not the TFP recommend TA range accounts for CYA. I have searched through every resource I thought could possibly be related and haven't even found mention of how CYA accounts for a portion of the TA reading. It seems like a MAJOR oversight for what is otherwise a quite thorough knowledge base.
1. Does anyone know definitely if the TA recommended levels accounts for CYA? For example, the pool math app says ideal recommended range is 60-80 for TA. If I test TA and the result is 90 PPM and just go off of that, then I'd think it was too high. If I account for CYA though, then I'd still be in range.
TA-(CYA x PH factor)=TAadj
Example: 90-(40 x 0.34)=76.4
[in this example, PH is 7.7 so the corresponding PH factor is 0.34. If PH were 7.6, it'd be 0.33 or if it were 7.8 it'd be 0.35]
2. Is there a way to contact site owners/mods (whoever writes/edits the articles) to discuss the ommission of this info?
I know that "You do not need to lower TA just to reach a target number." My PH keeps rising quickly though (no water features), so I know I need to get my TA down to better stabilize my PH. I have been using the calculated TA adjusted number because it's a more accurate/true reflection of the actual TA level. If the TFP recommended range is using the basic TA readings (that do not exclude the effect CYA has on those readings), that makes a significant difference.
Thanks!
Thanks!
