Synthetic turf infill (effectively sand) sucked into main drain
Agrabah
77
Las Vegas, NV
Hayward Aqua Rite (T-15)
I really should have used my robot for this but I wasn’t thinking. Unfortunately a fairly large amount was at the bottom of the pool and I swept it to the main drains expecting it to get sucked into the filter so I could use my shop vac to get it out but when I pulled my cartridges out there didn’t seem to be all of the sand that was sucked up so I am concerned it’s sitting in the plumbing lines probably around angled fittings. It doesn’t seem to be causing any issues with pressure but my ADD is kicking in and I feel like I need to do something. I have seen these “drain bladders” that you can attach a hose to and it pushes out with water pressure and can be inserted into the pump basket area and I can switch to main drain only so it pushes back the other way but since there isn’t actually a clog not sure it’ll do much.
Thanks.
What model pump do you have?
What valves do you have on your suction line?
Post pics of your equipment pad.
I think you are worried about nothing and any sand will come out in time.
I don’t have the model number handy for the pump.
Is it a VS pump?
If VS what RPM are you running it at?
Is it a VS pump?
VSP, yes. When the controller was set up they set it in two speed mode (I’ve been meaning to go back and change it but haven’t) 4 hours 80% and 5 hours at 50%.
I changed it to 100% for several hours and switched valve to main drain only for an additional boost to suck up what it could but didn’t notice anything. Might be a non-issue just figured I would ask anyway.
