Switching from Intermatic timer to suraielec WiFi timer
Dbrand325
2
New jersey
Fiberglass
Hayward Turbo Cell (T-CELL-5)
Hi. Looking to help wiring. New to forum
Currently have an Intermatic switch that controls pump, salt generator and heater. All Hayward products. Looking to switch to suraielec. Was wondering if it was the same set up as the intermatic.
Taking 1 and putting to com1.
Taking 2 and putting it to no1
Taking 3 and putting it to com2
Taking 4 and putting to no2
325,
Well, I believe that you are wrong... :mrgreen:
I don't see any Neutral wires in your current timer box, so you have no way to get 120 VAC.
Use a meter and test between pin 1 and 3 on the old timer.. I suspect that you will get about 220 to 240 volts AC.
Better to know for sure before you make any changes.
Also see the following post that includes wiring diagram for 240VAC.
