I have been reading a few treads on the conversion over to a SWG. When we had the pool installed back in 2017 I came to conclusion that SWG could damage or void the warranty on equipment due to corrosion. The last few years I've grown tired of Pool water testing results with adding 1 cup of PH down, 13 cups of this and that. Plus I start the season with stabilized pucks and then later in the season the pool company recommends to switch over to un-stabilized pucks. All pucks are put directly into the skimmer basket. Sometimes they dissolve quickly sometimes slowly. This makes it hard to keep the FC level at 2.5-3.5 difficult. Recently we started getting more skin sensitivity, because of that I'm considering to switch. I found in one of the treads the link to a comparison chart for SWG. A very useful tool.
www.discountsaltpool.com
I have read that Circupool has warranty that is longer than any or many others giving it a clear advantage. Given the size of my pool (approx 14,500 gallons) I believe it was recommended in one of the forums to get a SWG that can handle twice the capacity of the pool. So its between the RJ-30Plus and the Core-35. We live close to Toronto, Ontario Canada. So the summers are short. Open up the pool in May and close end of September or beginning of October. During this time we can have some hot weather.
A couple of questions:
1) Am I correct in assuming that the SWG cell gets installed after the water heater to the feeds (Jets) back to the pool and or Spa?
2) Also I have a Clear Blue Ionizer cell installed after the water heater. Is there an issue running these two inline? Should one be before the other?
I have added some equipment photos with the location of the blue ionizer.
I look forward to your feed back
Compare and Review Saltwater Chlorine Generator Prices and Features | DSP
