Super Vision Pool Lights???
rjcasserly
10
Tampa, FL
First post on TFP, hoping someone can help. New homeowner/pool owner, pool appears to have been built in 2011/12. The 4 pool lights (3 pool, 1 spa) have always been out of sync since I bought the home last year, so finally began the process to figure out how to resync, which requires figuring out what lights you have installed. See attached picture for the one in the spa that I drained to get a better look, but it says Super Vision 100.0046. Any idea on what this is, how to take out, how to resync, etc?
I'm also trying to get that clear lens cover off to clean the algae, which I haven't been able to do with a fair amount of prying. I also can't take the whole light out of the niche - when pulling/turning, it wants to pull back in/rethread to the original position.
Again, any help at all would be much appreciated.
Welcome to TFP.
That looks like this light...
It looks like Super Vision company is no more and Savi lights was acquired by Zodiac.
There are quite a few threads like this about Savi light failures...
You can try contacting Inyopools on their website and see what they know about the light. Say you came from TFP. They are our friends.
@InyoRob
Thanks a ton ajw22! Love these forums. I think you are spot on, after more Googling it looks exactly like the Savi Melody. Troubleshooting with Jandy didn't fix the out of sync issue, so I'll have to evaluate options but at least I now know what I'm dealing with. Many thanks again.
I am also new to this forum, and would welcome advice. Like 'R' above, I have a problem identifying lights in my lap pool. The installer has long retired. The lights, as best I can tell (attached) are "Super Vision 100.0046 Rev A, or E322822" and ajw22 has identified them as Savi Melody and the company is defunct.
Do I need a key to remove these, or can I just unscrew them?
I am assuming that there is no niche, that the conduit behind is water-filled, and I can remove the lights with the pool still filled? (Assuming that the conduit isn't cracked)
Can I replace them with brands that usually require a niche or do I need to replace them with an updated Savi model?
Many thanks for any and all advice.
JT
