I have a new Sundance 980 Series Spa. They have two cartridges - inner and outer. Inner is supposed to be replaced every 4 months and outer every 12 months.
I've never replaced filters per manufactures recommendations
In the past I've only had the pleated once per year recommended type. Instead of replacing the filter yearly, I've cleaned them and used them for 2-3 years.
The outer filter is pleated.
The inner filter is a spun-bound microfiber filter.
The Sundance, I believe, has bypass filtering, so flow during jets usage shouldn't be impacted.
Realistically, how often do I really need to change filters - and is cleaning a possibility for outer and / or inner filter?
