Summer Waves SFX1500 pump with GFCI
juhrich
7
Fort Smith, AR
Intex Krystal Clear
I've tried to put my pump on a timer with no success. Apparently every time the pump turns off the GFCI trips. So when the timer comes back on the pump will not start unless the GFCI is manually reset. Has anyone had this issue, and if so, is there a way to make this work?
So since my timer is plugged into a GFCI outlet, I should be okay replacing the plug on the pump? Of course this will void any warranty I'm sure. Thanks for the response.
