- May 9, 2021
- 140
- Plaster
- Jandy Aquapure 1400
I have been using the FC/CYA chart for setting my target FC. But I suspect my FC is low when using my spa. This is because my son has some hot tub rash. I read somewhere on this forum that spa has a higher bather load than the pool and that makes sense due to the temperature. So I am looking for some suggestions on what my target FC should be since I have a pool spa combo. I can set a different level on my chlorine generator for pool versus spa and previously the spa was lower than the pool. Now I think I should maybe set the spa higher than the pool. By the way I run my spill over for one hour in the morning and four hours in the evening.
My logs: PoolMath Logs
