Have you gone to the PoolSchool link yet and read
ABCs of Pool Water Chemistry?
The use of trichlor 3" pucks is pretty much industry standard teaching for pool water chlorination. What they fail to mention is that constant use of the pucks over-stabilizes pool water (CYA gets too high) and then the chlorine is no longer effective. Then, instead of fixing the problem, you are led by the pool stores to use ever increasingly expensive chemical solutions (algaecides, shock powders, etc) that only make the water worse.
If you want to follow the
TFPC Method , then you will need to read up on the links in PoolSchool and make the switch to liquid chlorine or bleach. You will also need to purchase one of the
Recommended Testkits (either the TF-100 or the Taylor K-2006) and get away from pool store water testing. Once you take control of your own testing, you will find that your pool is very easy to maintain using the methods taught here.
And, where are my manners!?!? I failed to say this - Welcome to TFP!
