I purchased a home with a pool in 2020. During my second season I noticed I was losing too much water. The pool had been painted by the previous owner and I learned this was done to cover up some structural issues with the pool. A large crack started appearing and quickly spanned the majority of the pool. This season I was finally able to afford a resurfacing. After having a chipout performed I learned my pool was not actually a gunnite construction but a concrete base with block walls. Additionally it appears not all of the blocks have been filled with concrete. The crack around the pool appears to only be in the plaster and not the blocks, though there are some big holes in the blocks now from the chipout, but the big surprise was to see tree roots growing behind the plaster spanning nearly the entire length of the pool. The contractor is advising to put a membrane along the portions of the block wall and then plaster over that. I'm worried the main structural issues of the pool are not being fully addressed and that the membrane and replaster will only last a short time before shifting and cracking again. I don't know what can really be done to address the structural integrity at this stage though. Mostly posting this for informational purposes but if anyone has insight on what questions I should be asking in regards to the structure or the membrane and it's longevity, I would appreciate it.
