- Mar 5, 2017
- 603
- Plaster
- Hayward Aqua Rite (T-9)
Man, I am not catching a break with pool maintenance lately. Was out of town for the week and came home to a almost-overflowed pool. Water level is 2 inches below overflow pipe.
Opened up auto-fill cover and the float valve is stuck in on position. Got it ‘kinda’ working again, but it’s gonna need to be replaced. We have a evaporative cooler that uses same floats, so I’m used to replacing them.
I have a replacement on hand, but when I put this particular one in three years ago, the threads in the PVC auto level bucket were stripped. To explain, you try to thread in the new float and first turn it grabs, then falls out. Female threads are basically flat. I used epoxy putty (grey stuff from Harbor Freight), mushed it up into flat threads, screwed in brass float, and it’s held this long.
Hoping for another alternative. I did buy a replacement float with pvc threads, instead of brass, hoping that might be a gentler connection-if that makes sense?
I have a thread die kit, but it didn’t work last time, no room to maneuver.
I’ll tell ya one thing, I’ll never own a pool without a auto fill float. Lifesavers.
