Storing pool equipment-freezing temperatures
JimMarshall
0
1,193
Oil City PA
The previous owner of my house took their pool equipment inside their heated basement every winter. Is this necessary? I don't really have the storage space inside for that. Can it just be well drained and left outside with a tarp or cover over it???
Hello and welcome to TFP! My pool is just about the same size (24' filled to 48"). I've owned it for almost 20yrs (only been controlling my pool the TFP way since last season and never looked back).
I can tell you what I have done since I have had the pump & filter regarding closing for the winter in WNY (still original by the way).
1. Drain my water to below the return in the pool (about 1") and add what ever you want to winterize the water
2. Cover both the skimmer and return opening inside the pool (I did replace the skimmer with one that has a flange for a "tuperware" type cover) (I also cover them because one year enough melted snow on the cover pushed out enough pool water that it was a little under 1/2 full when I went to open it)
3. Leave the hoses connected to the skimmer and return, but disconnect from the filter & pump. I cover those ends with a rag to keep critters from moving in, but allowing any water to be able to drain (just letting them lay on the ground beside the pool)
4. Drain my sand tank and place the drain cap on top of the valve
5. Turn the valve to winter
6. Drain the filter basket (using it's drain plug) attached to the pump completely (cleaning both basket & housing well)
7. After replacing the basket housing plug, I fill the entire thing with RV Antifreeze till it dribbles out of the fitting where the skimmer hose connects
8. Coil up the motor cord with a baggie tie close to the motor
9. Cover the entire unit with a tarp and tie a string around the base to hold it in place through the winter
Don't know if this helps at all, but just throwing it out there! (sounds like our filters might be similar so I'll throw in a pic of mine)
Our pool pump seized up after it's third winter outside. My pool guy who closes for me says he removes and stores pumps on most pools he closes. I see why now. It's the prolonged dampness that causes the issues. It may or may not happen, but the safest choice is to remove the pump and store indoors. That is not always easy depending on the installation, but yours looks pretty removable. If you are looking for folks to say they keep them outside and have no issues, you will certainly get those replies. But I can tell you it's not the safest approach.
Reactions: Tlou
How about my filter and heater?
No worries on the filter and heater. So long as both are properly drained/evacuated.
