I can't seem to get this thing to work correctly. The back wheels just seem to stay up off the bottom. It doesn't climb the walls and keeps getting stuck in the corners.
*I have the thrust jet at 11 o'clock
*I made sure the head float was all the way pushed in
*At first the tail wasn't "whipping" around but I adjusted the screw and when it does move it is whipping
*I did the RPM test and it has enough pressure
Below is a picture of it in the water. You can kind of see the back wheels not touching bottom. The second picture is of one of the swivel hose fittings. When I lift the hose out of the pool water comes out of these fittings. Should this happen? It is a new unit. I've only used it 3 times and never with any satisfaction.
I don't know which was more frustrating today the Polaris or the greenheads!
