I cleaned the chlorine injector like I do regularly but when I went to the pool in the morning no chlorine was getting into the pool . The stenner pump is running , I changed the duckbill check valve the tube inside the pump and made no difference. I changed the suction tube and discharge tubing and all ferrels but still no chlorine was pumping in . I have removed the duckbill check valve and now it is dosing . The system is operating at around 10 psi so it doesn’t require a duckbill but would like to have it installed for piece of mind . Does anyone have any idea why it doesn’t dose with the duckbill installed?
