Steel Brush?
Swim138
55
I hope this is posted in the correct forum. I have a slight waterline scale problem. I am better with CSI and pH now so shouldn’t be an issue after I remove what’s there. I’m going to use the method recommended for removing mild scale via steel brush and chems noted. What type of hand held steel brush should I get that will be safe for tile and grout?
Your tile manufacturer might provide cleaning instructions. I have NPT tiles and they recommend avoiding both steel brushes and pumice stones. I imagine the tiles are all pretty much the same. I bought some 3M scrub pads but haven't actually tried them yet. Tile Care, Water Balance & General Maintenance | NPTpool.com
