Hi I have a 4 year old pool with a Color Stamped concrete pool deck (1200sqft) it was sealed (ConcreTech NatureSeal) after built and then re-sealed again 1 year later. Now its been about 3 years since the last sealing and it was starting to peal and turn grey ish in spots.
I recently pulled out the pressure washer to wash off the deck and the flaking sealer and the next morning ended up with a bunch of streaks from the pressure washer. See Pics
I would like to know what the best solution would be to strip the remaining sealer or if that is even necessary, I have been told that by applying new sealer over top it will fix the problem. Not sure about that?
Thanks
Thanks
