Sta-rite system 3 help
Mar 31, 2018
2
Ramona oklahoma
Alright so I have a few questions. I have had a leak on my s7m120 cartridge filter for awhile now. I have been trying to figure out what is wrong with it. The leak comes from around the clamps so what I was thinking is that it was the o ring on the filter. I replaced the o ring with no luck. I have tried putting it on lubricated and not lubricated. I have gone around and cleaned every spot of where the o ring touches. I have looked very thoroughly for any cracks and have not seen any. I even put the clamps on in the order listed in the manual but to no evail. Is there a possibility that one or more of the actual clamps could be bad? Any help would be very appreciated. Thanks
Due to the age I think you already said what may be going on-the clamps. :( 11 yrs is a long time for something made of fiberglass and lives outside 24/7. I would think about replacing it. You might be able to replace just the clamps but the age worries me.
Kim:kim:
What type of lubrication are you using? Silicon based is required (pool-lube).
Does the o-ring fit tight around the base? i.e. do you need to stretch it just a little to get it on?
Do not over tighten the clamps. A back and forth tightening method per the manual is best.
Check for any small cracks in the filter base and top.
---- EDIT ----
I have some older extra clamps I could send but I doubt they are bad unless they are not tightening. PM me if you want to try a couple.
