We havd a 8-year-old 20,000 gallon salt water pool with an attached spa. We heat the pool w solar and although we could use our heater (Sta-Rite Max-E-Therm 400) for the pool as well, we only use it for our spa. Late last year something happened that caused the heater to cycle on and off.
I have the spa temp at 104F, starting at 72F it will heat for about 16-17 minutes until it reaches approx. 85F and then it will shut off, after about a minute it will ignite again. In the beginning it will typically heat for 75-80 seconds and then shut off for about 60 seconds. It takes me 30 minutes to get to 90F (before this problem I would have reached my set temp of 104F by then). I am able to reach 100F after 50 min but by then it is heating for 40 seconds and then shuts off for 80 seconds. After 1h I reach 102F.
I never see an error code.
The highest exhaust temperature I have is around 350F.
There is no rattling sound when I start it up, it sounds just like before.
I opened the casing and there is no debris, no rats nest and cables all look fine etc.
Any idea what I should look at next? I have read about the thermostat thing being corroded, but I am not sure how that would drive this behavior and not trigger an error? I am a newbie when it comes to trouble shooting heaters, so TIA for any help!
