Greetings.
My single speed pump is not working cycling on and off making a noise that sounds like a electrical surge. I already replaced the capacitor (2 different ones to be sure) with no luck. The pump starts and runs for about 2 minutes then starts the on/off surge noise routine. I shut it down.
My local pool store is booked solid until August 8 so in the mean time I am trying my best to keep the water circulating using a small Harbor Freight pump and a garden hose and running my robotic cleaner daily.. I have the chlorine level on the high end (8-10 PPM) and the CYA is at 60. TA is 100 and pH is 7.6. Hoping to make it until they can either rebuild the existing pump or replace it with a variable speed pump that ties into my pentair automation system.
Here is my issue. I installed a solar electric system on my home a year ago and therefore electrical cost savings from the VSP is not an issue for me. The options I face are 1) rebuild existing pump (new motor, etc) for about 900 dollars all in with a 1 year warranty or 2) replace it with Pentair VSP for about 2,800 all in with a 3 year warranty. Since energy savings is not a big deal for me (I generate much more than I use), I am inclined to take the rebuild alternative.
Based on my circumstances, is there any reason you would not take the single speed rebuild alternative and if so why?
Is there anything else I can do over the next 10 days to keep my pool from getting cruddy?
