Good morning fellow pool gurus! I am new to this pool thing and just recently purchase a home with a IG 15K plaster pool with integrated spa. I have some clue to what things do and then again have no clue to what other things do. My question is on the spillway from the spa to the pool it seems like i just get a little flow and to me it should be a good flow to make the waterfall look and sound good if that makes since. So i guess what I'm wondering is the spa main drain sucking to much water out verses putting it back in through the jet? Or does the main drain on the spa even work when just the pool is filtering? I know when i booster the VS pump to max it has a good flow over the spillway but not when the pump is at normal speed of 2200 RPM I have added some pictures of the equipment set up and the spillway of the spa so you have a idea on what it looks like. When it come to the equipment i am familiar with some of the valvles but not all. Any advice would be great to get me started in the right direction. Oh and the picture of the pool is when we moved in and i promise its not that dirty know!! LOL
