I have been adding some SpaGuard Enhanced Shock lately and I found an MSDS for it that lists the chemical components as below...
Can the group confirm that I am correct in the purpose of each component?
Thoughts?
- 58.2% Sodium Dichloro-S-Triazinetrione - This is the stabilized chlorine component with approximately 60% chlorine portion and 40% Cyanuric Acid portion.
- 10-30% Sodium Persulfate - This is the oxidizer, similar to Potassium Monopersulfate (non-chlorine shock), but unlike MPS it oxidizes faster, introduces less TDS and can be an irritant (?).
- 7-13% Aluminum Sulfate - (Alum) - This is flocculent, designed to capture and weigh down solids in the water to help the filter capture then leading to improved water clarity.
- 7-13% Boron Salt (Trade Secret) - I have no idea what this is doing...maybe a pH stabilizer and water softening?
Thoughts?
