I have a spa that has a spillover waterfall into the pool. I have the Intelliflow VSP set on a timer to switch between hi and low pump speeds. Most of the time the pump runs on low which is at 2500 RPMs. Normally, the waterfall spills over during BOTH high and low speeds, just obviously in different amounts/speeds of water flowing over.
All of sudden, the spa will not flow over during low speed. I can't feel water coming through the jets, even though nothing has changed with the valves or equipment, only pump speed has changed. if I turn up the speed of the pump too high (3500), it works.
Nothing has recently has changed with the equipment that I can tell, all the valves are in their normal position. Spa otherwise works fine in spa mode as well, valves turn off to the pool, water recirculates in the spa, jets all work, blower works etc.
Any idea why this is happening?
I am including a picture of our equipment set up.
