Spa spillover schedule: pentair
Titan7
846
Peoria, AZ
My friend has a pentair system, with automation, easytouch. How is this set up to schedule a spa spill over run, pool suction/spa return. They want to run this in place of the make up valve/spa bypass valve as the water only dribbles over the spill over when through the bypass.
Can this be programed or does a manual switch?
Go to circuit names> select an available feature circuit> scroll through the names to Spillway.
Go to circuit functions>scroll to Spillway> circuit function- spillway.
Settings> intelliflo> speeds> spillway> select the rpm
Schedules> spillway> set the timeframe and days to run.
