- Sep 8, 2018
- 58
- Vinyl
- Pentair Intellichlor IC-20
I've had a spa since new in Fall 2020.
Recently I noted that the spa displayed "Oh" and the pump was running continuously. I shut it off. The water was over 108º.
I've since been doing some troubleshooting. I first thought (hoped) that the kids and changed the filter cycle. They had not.
1) I've double checked and it is in "Standard Mode"
2) I've checked the filter cycle and it's set to F2 (2 hour filtration in 12 hour period). It is NOT set to FC.
3) I've opened the control pack hoping to find a stuck relay. Tapping them didn't change anything, and no obvious signs of damage / failure.
My first thought was that the kids accidentally changed to continuous filter mode. They did not.
Second, I thought a relay might be stuck, however the button behaviour doesn't bear that out.
Intended "Jets 1" button behaviour is to toggle between off, low, and high. However with my pump already running on low, pressing Jets 1 turns the pump to high. Pressing Jets 1 again turns the pump back to low. Pressing Jets 1 again turns it to high.
My Balboa Circuit board is a VS501Z.
Other thoughts / musings...
With the heat temp set below the current temp, the pump continues to run and I cannot turn it off. There should be a 2 hour time out (per the manual) but it runs continuously after that.
With the heat temp set above the current temp, the pump runs (as designed) and the heat light illuminates. Turning the set temp below the current temp results in the heat light extinguishing, but the pump continues to run.
It's acting almost as though the pump thinks the heater is running continuously (even though it's not based on the heat indication light and electrical consumption).
Start condition | First Press | Second Press | Third Press | |
Normal Behaviour | Off | Low | High | Off |
Stuck relay expected behaviour | Low (instead of off) | Low | High | Low (instead of off) |
Current behaviour | Low | High | Low | High |
