- Apr 5, 2022
- 14
When I moved into my house the existing pool had an AquaLink automation system setup. There were two valve actuators connected to the system, but only one of them was actually connected to a valve (the return side). The other actuator was laying on the ground and it was broken. This wasn't a big deal at the time because the heat pump heater that was installed was also broken and there was no need to switch between pool and spa mode. Well... I just had a new heater installed and now obviously want these valve actuators to work. Currently the existing one that is attached to the return side will cycle between the spa and pool returns all the way on when in "pool mode" and when "spa mode" is activated the valve will rotate to block most, but not all of the pool return jets... I would say they remain open about 25%.
So... my questions are... is the valve actuator on the return side supposed to completely shut off the pool returns, or is supposed to allow some minor flow still to the pool? Secondly, when I get the new valve actuator later this week and connect it... should I have it cycle from spa drain completely closed (pool drain and skimmer open) over to completely close the pool drain and skimmer... or should I close them 75% of the way (since the other actuator is still sending 25% of the water to the pool)? I would guess if 25% of the water is still heading to the pool then 25% of the water needs to drain out as well otherwise the level of the water in the pool will just keep rising.
I guess what's confusing to me is the behavior of the currently connected valve actuator. I would have thought "spa mode" would have closed off the pool returns completely (leaving the spa returns fully open) and then opened the spa drain full while completely closing the pool drains and skimmer... thus allowing the heater to only heat the water that is cycling in and out of the spa.
