HI all. I have the typical elevated spa drain into pool with pump off overnight issue. This pool has run without an issue for 5 years and I have taken care of it the entire time. In the past, I've replaced my Spa Check valve and this has fixed the problem. Now I have replaced it and still leaking about 6-8 inches overnight. Also, replaced all the check valves including the valve between my heater and chlorinator, the jet pump check valve which leads to the spa, the infloor cleaner check valve which also has lines in the spa, and the cleaner flow meter check valve from the cleaner return. I just did a complete new filter install/cleaning and applied magic lube where applicable to o rings. The problem stared BEFORE the complete check valve/cleaning...thinking that would fix the issue
With the pool pumps off...I can hear and see a fluttering and ticking sound at the Spa Check valve and also the cleaner check valve and flow rate valve. Both are pulsing open every second...and over time the spa begins to drain. I took off the spa check valve again and saw a small build up of calcium where the check valve rubber seal would sit, so i scraped and cleaned that off. Still the problem persists. ( I need to check the cleaner check valve for calcium as well - it was getting dark)
I did a smoke check using some incense to test for air leaks around all the valves and gaskets and can't find any leaks
I checked the Never Lube diverter seal on my Spa Floor Suction Drain, and it appears to be fine. I am replacing that tomorrow. The automated actuator works perfectly.
This one has got me really stumped.
Any help would be much appreciated
I've attached some pics to show my plumbing and flow and where the spa is in the morning below the spillover
