- Oct 4, 2018
- 92
- Vinyl
- Autopilot Digital PPC1 (RC-35)
Problem: Pool water continues to taste sour despite water apparently conforming to TFP specifications.
Background: I opened the pool this year in may with a slam, and balanced the chemistry as normal, but on the first swim my kids stated the water tasted sour. Everything tested in the acceptable range, and the water appeared clear, but nevertheless I raised the chlorine to 20ppm for a few days to be sure. At this time cya was around 20 and a solar cover was in use. The shock appeared not to affect the taste.
After this, another event added confusion. I had observed earlier that iron scale had formed a ring at the waterline and staining on the liner over the winter. After researching here, I purchased a bucket of vitamin C and some metal out and successfully removed the iron scale. Having removed the metal stains, I added washing soda to bring the ph up, and some baking soda to raise the TA(which was around 40 before the Vitamin C treament), but despite calculating and testing, I must have made an error because I achieved a 160 TA. I used muriatic acid over a few weeks and reduced it to about 90. Water taste is still sour, and the sourness persists even when the pH is relatively high.
Using the TF teskt kit, levels are:
pH 7.2
FC 6
TC <.5
CYA 30
TA 90
calcium - not tested
water is clear
Additives: I sometimes use coverfree liquid solar cover.
What could wrong here?
Thanks!
Dangerous
pH 7.2
FC 6
TC <.5
CYA 30
TA 90
water is clear
Thanks!
Dangerous
