Total pool automation which includes Alexa control for $605....
So finally finished everything up and it works great. Thanks for everyone's help.
I wanted to post this for anyone so they could see my journey which I finally had time to put together.
I did things a little differently instead of controlling the heater with the Fireman's loop I will be using 2 TH16's, one set for Pool temp the other set for Spa temp. Really what these are doing is just being a thermostat used with e-wink app(sonoff) scene logic. Created an automatic scene on each Th16 to look for Temp < than our = then turn the th16 switch on. Nothing is connected to the output of either TH16 Switch.
Then I use the 4ch Sonoff with relays for the pool and heater with 4 Scenes always running. 2 scenes for Pool, On Checks to see if the Th16 Switch set for the pool is turned ON. If so it does all the necessary things --- Activates intake and set valve actuators --> delay-->turns on pool motor-->delay-->then heater. And the second Scene is Pool of which looks for the Pool Th16 switch to be OFF and turns the off pool heater-->delays -->then turns the pump off. Same two scenes for the spa.
Now i can either enable the Pool or spa heater by Alexa by just saying pool or spa on or just turn either TH16 switches on in the APP ( again th16's are not connected to anything). If I want to heat and maintain a certain temperature I use the automatic/thermostat function on the th16's.
FYI my pool heater is set to 103 so it basically the same as now.. if I turn on the pool heater manually I have to make sure I don't leave it on forever, same as today making sure it is not set to spa or leaving it on.
I use the schedule on the 4ch Sonoff for Daily motor/cleaning. I will most likely put schedule a safety scene in for midnight to shut everything down, just in case.
Hope that makes sense
Thanks again for the help everyone's.
If anyone wants to know here is the parts list.
2 Sonoff th16 $44
Link
2 24Vdc coil 220 Relays $
36 Link
1 Sonoffchr3 $29
Link
1 24 Vac trans $20
link
1 Grounding block $7
link
1 Terminal locks $15
link
2 24VAC Valve Actuator $135ea
link
2 Saddle Clamps $42ea
link
2 weathproof box & misc $100
total est $605 for total pool & spa automation... total of $340 if you take out the valve actuators
Brians of the system I located closer to the entry of the Equipment area.
The high voltage stuff is located behind all the equipment and I did not want to move it...
