Hello all, first time posting on this site, second year as a pool owner. I have browsed the forums as a guest and solved a few problems. I must say that everyone here is great with all the helping and knowledge!
However, I have a problem with my pump. Today I noticed that my jets were not on, but the pump was warm as if it had been going a few hours ago, but it was now off at 5pm.
I removed both the 'on' and 'off' timer needles, and the breaker box in the basement had no tripped switches.
Both Type-T fuses on on the main switch box in the pump house are fine.
Timer wheel still keeps track of time and I have an outlet attached to the main on/off box (not the same as the timer box) that powers anything hooked up to it.
I should state that we kicked up a ton of waves in the pool yesterday, but before hand, I turned the pump off at the main source (so the skimmer wouldn't suck up air) ,and the timer had lost track of proper time.
Later on when I remembered, I set the time and everything seemed fine.
I could not find anything already posted about this, but I am sure there is.
Anybody ever have this problem? Should I be looking more into maybe replacing the timer, or is it pump related?
I am not really a DIY person so if it were to be pump related, that would be a major bummer.
Any help, leads, or suggestions would be much appreciated!
I also have a few other problems, and will be posting some pictures of my setup as well as an introduction here tomorrow
