- Jul 21, 2008
- 60
Code:
UPDATE: Installing the correct voltage time worked. I'm such as DumbMule
I have a new Intermatic timer (T101R) that I just hooked up to my pool. I attached it to the wall and ran two conduits all seemed well. I took the Line to A and 1 (where the clock motor was installed) and the load to the pump went to 1 and 2. Each one has a ground going to the ground post in the box.
The pool pump runs off the new switch in the timer just fine; however, the timer clock doesn't tick. It also seems to arc off the back of the metal box everytime I flip the switch... I only see that happen at night.
This seemed pretty simple but I haven't been able to conquer this yet. What am I missing?
Help!
