- Mar 17, 2019
- 610
- Plaster
- CircuPool RJ-45 Plus
I am looking at picking up a solar-powered skimmer to help with surface debris. Based on research here, it appears that the 2 viable candidates are the Ariel by Solar Breeze and the Betta by Instapark. I suppose that not many have owned both, given that both are somewhat new, but looking for opinions on these skimmers.
Based on my research I put together a quick list of pros/cons between the two, in no particular order. Please provide any feedback based on your personal experience.
Size of debris tray - Betta's seems a little bigger.
Customer service - Instapark which is China-based but has an office in CA gets good marks for issue resolution. Solar Breeze is based in AZ but have not found any experience.
Availability - Betta is currently available in 2 of their 3 colors, but Ariel seems to be on backorder.
Battery - Because these are solar devices this can be subjective, based on the pool's latitude and hours/sun/day. However it seems like the Betta will pretty much run 24/7 in a sunny climate such as mine. I have read that Ariel won't make it through the night, as opposed to its predecessor, the NX2.
Remote control - Betta's controls on/off and direction of travel. Not sure if Ariel has one.
Durability/Reliability- Ariel's owners have reported that because of its speed it tends to crash into walls, thus cracking the frame near the bumpers. Betta owners have mentioned that replacement parts (props, etc.) have been needed. Both have a one year warranty.
Cleaning capability - Both seem to clean very well.
Suitability for salt pools - Ariel: yes. Betta: yes I think. I believe their earlier version was not but the current one is.
Cost - Betta $589. Ariel $468???
Suction skimmer conflict - This relates to the tendency of the device to get pull away from the suction of the skimmer while the pump is running. It probably can't be evaluated due to various pump speeds. If I do have a conflict I may need to run my 2-speed pump on low speed (not a bad thing).
Thanks.
Thanks.
