- May 22, 2021
- 195
- Plaster
- CircuPool RJ-60 Plus
Hi All,
Considering a non roof based solar heating system. I am looking at these guys Solar Pool Heater Full DIY Kits - Heliocol, SwimEasy, SwimJoy, SwimLux and not really into the DIY black hose setup. I do not want a roof setup because of putting hardware thru the shingles and the HOA hassle
Does anyone have experience with SolarPoolSupply?
Here are my calcs assuming I put in 4 4x10 foot panels (160sqft) its pricey though ($1800)
•1000W/10.8 sqft is what sun gives at noon max
- Assume 50% efficiency for panels
- 1.162 watt-hours raises 1 liter 1C
•My pool is 8900 gallons X 3.75=~34,000 liters
-I need 39,000 watt-hours to raise the pool 1C
-39,000 Watt-hours/1000 *0.5* 10.8 =840 sq ft to raise pool 1C in 1 hour
- 160 sq ft heating panel/840 sq ft=0.2C every hour at max Sun
•Figure 6 hours of Sun average with lower efficiencies other than noon- guesstimate is 1C temperature raise for 8 hours of daylight (Mar-October)
I would use a submersible pump (maybe 1HP 30ft head) due to where the main pool pump is and where I would put the panels (They would be ground level with 50 ft horizontal to and for not including length of run thru the panels)
Thanks!
Thanks!
