- May 14, 2013
- 157
- Plaster
- CircuPool RJ-60
I have the rooftop solar heater panels for my pool. They were replaced recently due to age deterioration and work well. They put in air bleed valves such that they drain when the pump turns off (I don’t believe the previous system had them as I never heard them back then). When my system turns ON, I get a lot of loud banging and gurgling through the pipes on the roof and in the equipment, and big bubbles at the pool jets as the air is pushed out. Sometimes it seems as though some air remains in the panels as I see bubbles for quite a while afterwards. Why are these valves necessary? Why must the water be drained out each time? I have no freeze issues here. Thanks.
