- Jul 22, 2023
- 266
- Plaster
- Pentair Intellichlor IC-60
Nope, just make sure you run conduit from the pad to the location of thesolar array for a 2 wire temp sensor. That sensor gets tied into the intellicenter. That plus an extra valve actuator and the intellicenter has the logic built in to control the solar.Do I need to buy a Solar touch
Are those sensors the Pentair 520272?Nope, just make sure you run conduit from the pad to the location of thesolar array for a 2 wire temp sensor. That sensor gets tied into the intellicenter. That plus an extra valve actuator and the intellicenter has the logic built in to control the solar.
No sir (and frankly I don't totally understand the logic, but I do read the manual lol) the solar temp sensor is to measure the roof temp in the area of the panels not the water temp. I think the logic is by measuring the roof temp it reacts faster to changes (cloud cover etc) since the delta between pool water temp and solar temp to activate is so low.@Ahultin
I know squat about solar, but I thought that the solar sensor was used to measure the water temp in the solar panels???
Or am I just confused?
Correct. The solar sensor compares the temp at the panels with the water temp.So, I already have two sensors into my Intellicenter, one air temp and one water temp. Are we saying I need a third air temp close to the solar collectors?
Is there a place to see this temp or calculated delta on the app?Correct. The solar sensor compares the temp at the panels with the water temp.
You have to configure the solar heater in order to see it and set it.Is there a place to see this temp or calculated delta on the app?
I actually thought the way this works was I would set the temp we like the water, let's say xF. No matter what the temp is outside, it would know whether to route through collectors of not (and start and stop based on difference from that). Let me see if I can see those in my app without having a heater configured.
Yeah, I did. I guess I'll understand once I have the system setup, if it is all relative to an air or water temp, then if it is 65F but I want it 73F, I would need to set the app different times of the year (by setting the deltas)? As I said, I'm sure it will make sense but wouldn't have thought it would be relative vs. user sets a desire temp and system figuring out what to do from there.You have to configure the solar heater in order to see it and set it.
OK, now I get it. The second step was what I was missing. Thank you for explaining it in detail.Maybe I am not explaining fully. There are two steps to setup.
1. Setup as a heater in configuration. Here you set the delta between pool water and temp at panels for both starting the panels and stopping the panels.
2. You setup in schedules your desired temps, high and low ( since the solar pool heat can also do nocturnal cooling)
In my case, the wife likes ~88° so in schedules I have the pool set heater set to solar only and set to 88°. When the panel temp exceeds current water temp by 4° the valve actuator opens on the solar bypass, running the water thru the panels. Once it reaches the desired temp, or that temp differential between panel and water becomes to small, the solar bypass closes again.
