I've heard these mentioned here but never really looked into it. I don't want to overtax the pump but am trying to find a way to maybe reduce the filter pressure in terms of less frequent DE changes.
AK...thanks....so I've seen skimmer socks that look like they fit over the top of the round basket and sort of drape down inside. Then, I'm pretty sure I saw others that cover the basket from the bottom - which would seem to be more effective given that the sock would cover all the openings around the basket. Can't imagine that the former method would really do much good (?) Can you - or someone else - recommend any particular type or brand?I’m using skimmer socks
AK...thanks. Just came across the Impresa that you provided a link to. Some reviewers say it's hard to get the thing over a hayward skimmer basket - especially due to the handle in the middle. Another idea I came across is to put one of these on the pump strainer rather than the skimmer basket (?) Guess it's worth experimenting with.
My goof...sorry... I got confused by seeing a picture of a blue basket and thought it was a blue sock over the bottom of the basket. You're right - wouldn't make much sense to run the risk of the thing getting sucked down into the pipe! Biggest issue appears to be fitting it over the basket handle.but the sock ends up getting pulled (at least partially) into the pipe.
My skimmer is Hayward and I have no major issues.AK...thanks. Just came across the Impresa that you provided a link to. Some reviewers say it's hard to get the thing over a hayward skimmer basket - especially due to the handle in the middle. Another idea I came across is to put one of these on the pump strainer rather than the skimmer basket (?) Guess it's worth experimenting with.
And so you have a handle in the middle of the skimmer? Here's another concern: I've been told that my frequent DE filter pressure increases may be associated with algae, despite the water being clear. I read one the Amazon questions that discussed how fine the sock filters - says down to .2 microns. So will the sock catch some of this algae (if indeed that's the problem...)?My skimmer is Hayward and I have no major issues.
The handle of my skimmer basket is in the middle, but swivels and rests on the side.And so you have a handle in the middle of the skimmer? Here's another concern: I've been told that my frequent DE filter pressure increases may be associated with algae, despite the water being clear. I read one the Amazon questions that discussed how fine the sock filters - says down to .2 microns. So will the sock catch some of this algae (if indeed that's the problem...)?
I wouldn't see why there would be other than letting them fill up too much and dragging down on the operation of the pump.I dont think there is a con for using them
