After having our pool (see signature) go green over the winter ... I've just finished with SLAMming the pool. All the algae is dead and I'm ready to get all that detritus out of the pool. The green color has been gone, so now I'm trying to turn pale milky cloudy water back to clear. Keeping the chlorine levels high to prevent a relapse ... the pale milky color has held firm for almost two weeks straight.
Bought a new filter pump (same as described in the signature, see pic here) from the local sporting goods store. For our small backyard pool, the original 1000 gph filter pump that came with it actually did a pretty good job over the first two years of owning the pool. But I never actually needed the filter pump to clear dead algae out of the pool. Since the original filter looked so cruddy, I just decided to replace it with a new one expecting to have no trouble clearing out the dead algae.
Not so fast. The new pump, when it's got a new filter, pumps great for about 20-30 minutes. The pool's intake jet is nice and strong at first. But then, before long, the intake jet slows to a faint trickle and I notice a gurgling air pocket in the clear tubing coming from the intake-jet 'mouth' of the pump (the 'mouth' that feeds filtered clean water back into the pool).
I thought the pump itself was failing mechanically. I disassembled all the tubing and equipment, reattached everything, PUT IN A NEW UNUSED FILTER, and started over. SUCCESS! ... but only for another 20-30 minutes.
I learned through trial and error that the problem really is the filters getting 100% clogged with dead algae too quickly. The pump runs nice and strong with either (a) no filter cartridge or else (b) a brand-new filter cartridge.
So at this point, what are the options for clearing the pool of dead algae debris? I hate to substantially upgrade the filtering system on a cheap pool (~$350 in 2017), but at the right price point I would consider that. Otherwise:
a) Can I hire a pool-cleaning service to come out and vacuum the pool's water? Haven't priced it, though. Could maybe borrow a pool vacuum from someone ... have to ask around.
b) Can I stick with my cheap filter pump, but do something to the filters to make water pass through a little more freely a little longer while (hopefully) still getting decent filtration? Maybe cut some slits or poke some holes in the filter cartridges paper 'fins'? To prevent them from 100% blocking the flow of water?
Any other potential solutions I'm overlooking? I have stuck just with chlorine (+ a little CYA) while SLAMming and want avoid flocculents, algaecide, clarifiers, or anything like that. But I don't know ... does it sound like I'm at the point of needing some kind of additional chemical help?
Thanks in advance for any advice anyone may have.
