Small Skimmer Basket
Works a lot better when the basket completely fills the hole. Otherwise debris in the water will follow the path of least resistance around the outside of the basket and into your plumbing.
Do you know the skimmer manufacturer and model number? If it happens to be a Pentair/Sta-Rite/SwimQuip model U-3 (look at the underside of the lid; it may say "U-3" or "08650-58" or "08650-0158"), the best basket I've found is this one: Val-Pak Products V22-110 U-3 Skimmer Basket. Perfect fit, weighted so it stays in place while the pump is off, built to last -- I think it's significantly nicer than the OEM baskets from Pentair.
Reactions: itsmike
What kind of pool do u have? Often the skimmer will have a name on the lid to help you identify it.
