Help! Second year with our pool. Last August the pool turned green and we haven’t been able to get it cleared up. We just got our Taylor test kit and started the SLAM process on Monday night. I have attached a photo of our tests since then.
Obviously we are only a few days in, but chlorine is staying really high. Our home test showed 18.2 FC the morning after we added chlorine, and then 17.5 by the end of that day - not much was consumed. We added another gallon last night for good measure. This morning we tested 22.5 FC at home and were baffled at how high it was so we went and got pool store testing which said it was 14.42. When my husband got back home he retested that same water and it was 17.
Couple questions:
-How do we know our results are accurate? We follow instructions and have watched videos on the testing.
-Why wouldn’t the chlorine drop more on day 1? I’ve heard about people having to add chlorine every few hours to keep it at SLAM levels. How do we know the process is working? The water color hasn’t changed at all. Still green. We vacuumed last night and don’t feel like it did much.
Other info:
-Over the weekend we drained the pool to 1/3 to get CYA down, which it did. We refilled with our well water filtered through an RV filter.
-We had our equipment inspected last year and all checked out. We replaced sand, too.
-We have tried adding Metal Out and floccing the pool with no success. Also lots of backwashing, vacuuming, running pump 24/7, etc.
-We had the store test for phosphate, which was through the roof. But have seen advice that that doesn’t matter as long as you have enough chlorine. Posted those full results, as well.
Any thoughts on our next steps? I feel like we’ve been trying everything.
Couple questions:
Other info:
