My newly acquired pool has two plugs and no open holes in skimmer bottoms. So no water is drawn in through skimmers. Is this normal? Should I remove a plug? Water seems to get to pump.
Blue is capped… old hot tub area that was connected to pool I believe.What other suction sources does your pool have? Can you tell us where the yellow and red lines are coming from? Is the line circled in blue capped? I think we would still like to see a photo of the skimmer with the plugs.
I did remove plug on patio side of skimmers
I will try that tomorrow. Thank you.This would normally be the port connected to the pump. Try slowly closing the grey valve on the red line and see how it effects suction in the skimmer. You should be able to determine if that line goes to skimmer(s) or main drain.
I was curious as to that as well. We owned this house 3 years back, sold it, then just repurchased from the same people. I didn’t remember plugs in the patio side hole so I asked the previous owner if he had plugged or had anyone do work on the pool or closed it for the winter. He said he had not and that they would be the same as when we sold it to them 3 years back. He said they had drained it and cleaned the plaster the refilled it 6 months later but nothing done to skimmer holes. I will say that the main drain has currently some debris over it so with the skimmers capped it would make sense as to why the pump was having a hard time drawing water and opening those ports has now helped it tremendously in drawing water. I bet the yellow and red and the main and skimmer draws and I will determine tomorrow which is which by closing the cable on the red circled pipe.You haven't shown pics of the plugs or skimmer, but is it possible these are winterizing plugs that were no removed? Does you pool get closed off-season?
Red circle is main drain and the yellow is the skimmers.I was curious as to that as well. We owned this house 3 years back, sold it, then just repurchased from the same people. I didn’t remember plugs in the patio side hole so I asked the previous owner if he had plugged or had anyone do work on the pool or closed it for the winter. He said he had not and that they would be the same as when we sold it to them 3 years back. He said they had drained it and cleaned the plaster the refilled it 6 months later but nothing done to skimmer holes. I will say that the main drain has currently some debris over it so with the skimmers capped it would make sense as to why the pump was having a hard time drawing water and opening those ports has now helped it tremendously in drawing water. I bet the yellow and red and the main and skimmer draws and I will determine tomorrow which is which by closing the cable on the red circled pipe.
