I've already searched the forums and INYOPools but can't find an exact match.
www.inyopools.com
www.inyopools.com
I've also tried e-mailing INYOPools and Waterway, but haven't heard back.
Thanks in advance for the help.
We bought the house last summer.
Characteristics:
I need:
Pictures:
Pool Skimmer Parts | Inyo Pools - INYOPools.com
Browse our extensive collection of pool skimmer parts, including baskets, weirs, lids, and more. Keep your pool's skimmer system in top condition with genuine replacement parts designed for compatibility and durability. Shop now to ensure efficient debris removal and maintain a clean and...
OEM Weirs Parts - INYOPools.com
OEM Weirs - INYOpools.com has the largest selection of swimming pool and spa replacement parts with over 70,000 parts in stock. Order today and save!
Characteristics:
- In-ground pool
- Constructed in 2005 (?)
- The pool opening is 8-3/4" x 5-7/8".
- The lid opening is 8-3/4".
- The lid is a "POUR-A-LID" and separate from the skimmer, so I don't think that helps with identification
- The diameter for the float valve is 6-1/4", and there's an aged gasket in the bottom of the skimmer.
- The only characters I see printed on the skimmer are 519?S and R1 on opposite sides of the basket retainer tabs. The ? is covered by a circle in the plastic.
- The installed basket is a Waterway 519-3240 that fits with the squared-off sides. This basket goes with a Waterway Renegade, but the dimensions at INYOPools don't match, and my skimmer doesn't have venturi plumbing.
- There is a tab hanging down from the top of the inlet with some foam still stuck to it.
- I don't see any holes, indents, or posts for the weir door pivot. There are small blobs in the bottom corners where pivot tabs may have been located. I can't tell if this is just calcium buildup, grout, or a purposeful patch. I don't want to try breaking it off and risk a leak.
I need:
- Weir door - debris floats back out into the pool when the filter is off. Perhaps this spring-loaded model? Weir, Swimrite 8 1/2in (939) - INYOPools.com
- Basket with a handle - mine one is hard to get out
- Float valve - I'd like the possibility of some main drain action
- Gasket
Pictures:
