Hi - we have a 20-year old pool that we just had renovated: New plaster, tile, coping, and they also replaced both skimmers. After the renovation, the new skimmer is now sitting about 1.0 to 1.5 inches below the coping. (It was flush prior to the renovation). This was due to the original pool not being level. Note: other areas of the pool deck were also lower than the coping before the renovation and it shifted to different areas after the renovation.
We had a concrete lifting company out to fix about 90% around our pool, but they are unable to fix the area at the new skimmer. The lifting company felt that it could damage the skimmer.
My question is: Is it possible to just chip out the concrete around the new skimmer and then pour new concrete? When they replaced the skimmer, they packed stone/dirt around the skimmer, but only put concrete on the top 3-4 inches. The renovation company is telling me that they should have put concrete the entire way down around the skimmer, I really dont think that is the case unless they put dry concrete in there.
What is the solution here? Do we need to have this new skimmer removed and replaced? Does the pool need to be drained to do that? Or, could they chip out the concrete around the skimmer, then lift the pool deck, then add new concrete around the skimmer to be flush? Are there any other solutions?
We are using a renovation company that has a good reputation, everything else is good. They have been out to review the situation and said they would try to chip out the concrete, but they have not done the work yet because i think they are unsure and concerned about damaging the skimmer.
