Apologies if I have the terminology wrong, but I am referring to the o-ring shown in the attached photo. (By the way, if you happen to recognize what kind of skimmer I have, please let me know! There was a sticker identifying it as an "Admiral" skimmer, but the model number was washed away...)
I noticed that the o-ring is leaving a little bit of a "skid mark" on my float valve assembly and assume it's probably about time to replace. I can't really find any info about how to do this properly -- perhaps it's too simple a task for anyone to bother writing about?![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
What I'd like to know is:
- Is it indeed serviceable / safe to remove?
- Can I replace the o-ring with water in the skimmer, or do I need to (partially) drain the pool first?
- How should I go about it, exactly? It sits pretty snugly in its groove, so I'm thinking I'll probably need to pop it out with a flathead screwdriver or something. (Please let me know if this is a bad idea!)
- Any caveats or precautions I should take?
