- Jun 4, 2024
- 52
- Plaster
- Jandy Aquapure 1400
I have a spa that spills into the pool and two sheer decents. If I get a VS pump and run it at 1200-1800 will it still spill over okay? Just can't figure out how the lower speed affects the pools performance? But yes, based on the chart I've seen here a few times if I run 24/7 it's over $200 a month. Currently running 9 hours a day I believe. Thank you!
