Is it necessary to have vacuum pool cleaners climb up the walls in your pool? I have something similar to the AquaNaut® Series vacuum cleaners sold by hayward that has 4 wheels. I read in there that it needs to turn 11-14 rotations on the wheel to be able to climb walls, which is recommended by the manufacturer, problem is i want to cut back on my PG&E bill in running the pump at 3300 rpms just to achieve a 11 rotation on that thing. It also states in the manual as well that if i get it to rotate 8 times, it will just clean the bottom but not climb walls. So i find that if i run it at a 2700 rpm speed I can achieve the 8 rotations required, but again my question comes back to: Do I need to have the vacuum climb the walls? Or is cleaning the bottom all i really need a vacuum pool cleaner for? I have a pool guy that comes once a week to brush the sides, so would that be enough reason to not have the vacuum climb the walls?
